IH 504 injector line leaking
Roscoe22
My IH 504 has a fuel leak where the #2 injector line from the pump attaches to injector,nut is tight,runs fine,but a steady drip that falls on pump,>Parts and repair manual show no seal at that point... Any ideas?? Thanks
Take the line loose and pull the nut back and look closely to see if you see a crack where the ferrel end attaches to the line. Put it back and retighten. If it still leaks regardless if you saw a crack or not it is probably there and the line needs replaced.
Any ideas? Here's one more. Before replacing anything, I would first look at the alignment of the end of the injector line where it attaches to the injector. Does the last few inches of line look like it's directly in line with the seat in the injector body? Lines do bend (or get bent) for various reasons. If the end of the line appears slightly higher, lower, or off to one side from straight in line, I would try correcting that first. Loosen the line nut a couple turns, then using two combination wrenches, (1/2" or so) slip the open end of one over the line where it looks like it needs to be "corrected". Slip the open end of the other wrench into the box end of the first one. Using that for leverage, the end of the line can be tweaked a little with no damage. Sometimes it takes a couple tries from different angles to achieve the desired result. Then tighten down the nut as much as you feel comfortable with.
Last, when/if the line looks straight, then just loosen the nut a couple of flats, jam it down tight. Loosen it again and jam it down again. Repeat this two or three times. You'll notice that each time you jam it down, the wrench travels just a little bit farther. That's often just enough to make a difference, and it costs nothing. Dry it off, start it up and see what's gained.
Thank you both for your help,I will try to check it out today..
Problem solved,had to heat nut on line to loosen,had not been off since valve job 6 years ago.. Loosened and straightened angle on line and tightened couple of times,no more leak...Thanks to all of you folks for your help.
