IH 504 injector line leaking
Roscoe22
My IH 504 has a fuel leak where the #2 injector line from the pump attaches to injector,nut is tight,runs fine,but a steady drip that falls on pump,>Parts and repair manual show no seal at that point... Any ideas?? Thanks
Take the line loose and pull the nut back and look closely to see if you see a crack where the ferrel end attaches to the line. Put it back and retighten. If it still leaks regardless if you saw a crack or not it is probably there and the line needs replaced.
