05 Ford F 150
37 chief
Lucky me. I need to buy the complete front hub, caliper assembly for my f150. The hub comes with bearings, studs, and rotor ready to mount. It is held on by one large nut, torqued to 190. The nut should be replaced each time the hub is changed The nut has a lock with a cotter key. Is it really necessary to replace a $13.00 nylon lock nut x2 each time? I would think red locktite would be just as good. Anybody done this? Stan
I did it once, really twice, once each side.
Had to go buy a socket at Harbor Freight.
The nut tightens down solid, that sets the bearing preload. The hub assemblies warned no warranty unless a new nut and torqued to spec.
I did use new nuts, I did not have a torque wrench that went that high, so I guessed.
Everything went well, one side was a little tighter than the other, but it didn't get hot. So far no problems with it.
Only thing I would have done different would have been ceramic pads.
I used semi metallic. They were spongy and ineffective. I assume they wore in and got better.
I am a former Ford tech and while employed by Ford, they all got reused. I replaced a front hub on my sons Navigator about a year ago and I called the same Ford parts man that I worked with and again asked him if they had that nut on hand. He again said to reuse it. Said they dont stock them or order them. I torqued it down, keyed it, and put a generous dab of RTV on the outside of the nut. Only local source for the nut was Dorman and it was two days away. I try to avoid most Dorman products anyway. My $.02 worth.
(quoted from post at 05:00:00 10/14/21) I am a former Ford tech and while employed by Ford, they all got reused. I replaced a front hub on my sons Navigator about a year ago and I called the same Ford parts man that I worked with and again asked him if they had that nut on hand. He again said to reuse it. Said they dont stock them or order them. I torqued it down, keyed it, and put a generous dab of RTV on the outside of the nut. Only local source for the nut was Dorman and it was two days away. I try to avoid most Dorman products anyway. My $.02 worth.
I have never been able to get those parts either unless I ordered them. Dorman sometimes you have to use them : ( BTW not all is bad their SS brake line kits are nice I prefer them over other brands...
