Glen D Anderson
With respect to the attached OEM service information for the transmission check valve modification designed to solve the lack of hyd. pressure after initial start up, I have some findings to share.
Last year we performed this mod. on our 64' 3020. After installing the check valve in the elbow & admiring the finished product it hit me like a facepalm "I just installed a 3/8" check valve in a 3/4" fitting!"
Knowing that the circuit could potentially see the max. output of the pump which could be close to 20 GPM on paper I started to get concerned so I installed a pressure gauge in the return circuit & installed a jumper hose in one of the SCV outlets to test.
With the engine running at at high idle, hyd. oil ambient / shop temp., SCV cycled with a loop hose on the breakaway, back pressure started at 125 PSI. I continued to run the test for 15 - 20 minutes to see if the back pressure would drop as the oil heated up & was surprised to see the back pressure take an immediate 25 PSI jump up to 150 PSI out of the blue for no apparent reason.
I wasn't happy with what I saw so I removed the fitting so I could remove the check valve to re-test & what I found shocked me. The check valve cage had been pushed off the body & was sitting in the bottom of the fitting along with the spring & check ball. When I installed the check valve I had only drilled the fitting deep enough to accommodate the threads of the check valve thinking that it would help hold the cage on the valve. That apparently didn't work. LOL
Anyway I removed the check valve completely & re-tested again this time the back pressure had dropped to just under 60 PSI.
Now I realize that in the real world 95% of the applications out there will not have the tractor operating at that high of a flow rate so the restriction of the 3/8" check valve may be a moot point. However, if you happen to be in that 5% that uses a loop hose to pre-heat your hyd. system in the winter or perhaps you pull something like a Valmar air-seeder you'll want to take note.
FWIW, if I have to deal with this kind of issue in the future I think I will be installing a 3/4" check valve at the outlet fitting & shortening & re-flaring the steel line to accommodate. It'll be more work & $$$ but will result in a better fix IMO.
Food for thought....
JD Service Literature
Fitting with check valve installed
Engine speed during test
Back pressure with check valve(possibly fallen apart)
Back pressure without check valve
Possible location for external check valve
