K Effective
I'm casually looking at a JD 6140D that sports a 1000 rpm PTO. I see no indiction that this can be switched to 540: no spare shaft storage in the rear, no obvious way to easily remove the current shaft, no indication in the cab to swap...
Are there single-speed PTO tractors in this model, and if so, is it reasonably possible to swap to 540, or and expensive ordeal if even a possibility?
I have only one implement that could be converted to 1K- my MOCO, which would be the main purpose of this tractor. This unit might replace my open station 4430 from the mower and, with a loader, replace my 5400 at the same time!
