10006 Deutz
I do not know the serial number pattern on them. Maybe someone else on here does. 74 is the only thing that would make any sense but not I am not certain. However most of the time the last numbers are sequential. I should look at mine sometime and could see if that makes sense. I think the first number you listed is actually F6L912 which is the engine model.
What I can say is that there are different features that can help determine about what year it is. Is its belly (engine/transmission/rear end) gray or black? Though it could have been repainted. Does it have helper cylinders on the 3pt lift? Does it have the arm running along the left side of the engine for steering or does it have the fully hydrostatic power steering? Does it have a pre-cleaner on top the hood supplying air to the air cleaner?
If you can provide any pictures that would help also.
Thanks, Dan
Belly is grey. I think the helper cylinders are there to slow the drop????? It has the steering arm along the left side of the engine. No precleaner on the hood. There is another tag on the right side just above the front axle.
You have a "grey belly", an older one. That is an early 70's model, pre-1975. Narrowing it down from there is tougher, but that is the big break between the older and newer ones. Our first Deutz was exactly like the one you have.
Yours should not have any helper cylinders, or at least I have never seen a grey belly with helper cylinders. What you might be seeing those cylinder looking things that are mounted horizontally connected to the arms that are for sensing the draft for draft control. The true helper cylinders do aid with raising the 3pt. The newer 100-06's with the helper cylinders had a 3pt lifting capacity (at hitch points) of an impressive for their size 11,023 lbs.
The tag above the right side above the front axle is for the tractor information. The tag on the engine is strictly for the engine.
I added a picture of our original Deutz. Dad bought it used in 1977 and we traded it on a Deutz-Allis 7110 in 2002.
Have a great day!
numbers on the front tag are 7927/1825 also 1530 kg, 3740kg, and 5270 kg. Those helper cylinders are vertical. Your picture is very close. Yours has the headlights up front where mine has them on the rear fenders.
