10006 Deutz
teddy52food
Does anybody have a picture or diagram of the brake lines & how they are fastened
to the master cylinders? When new there was an equalizer on it but now that is
gone. Each cylinder has 2 outlets which lines go where? This is on an old grey
bellied tractor. 2WD.
I will try to take some photos tomorrow from either our 100 or 130, or both. If I remember. Ours are newer, but I believe the brake setup stayed the same.
There is an aftermarket master cylinder kit available for those. Bolts right in place of the original master cylinders. Let's hope you do not have to go there, but they are available. Landwehr's has them in stock; I want to say around $250.
Dan
Sorry I forgot to take pictures today. Hopefully I will get them tomorrow.
Looking at my records, I do not have the receipt in front of me,but back in April of 2017 I bought that master cylinder brake kit, the two shift knobs and some paint from Landwehr's for a total of $360. My estimation is the brake kit was around $300 of that. I would call Landwehr's (http://dalesdeutz.com/) and have them ship you that master cylinder brake kit if I were you. Price may have went up a little since then, but it is both master cylinders.
I had bought that brake kit for a 100 06 I had bought and was going to use, but then life got in the way (marriage, kids, etc) and then I changed the kind of farming I was doing and really did not need a 2wd 10006. I did get the brake kit on but the brakes were leaking fluid internally (hopefully yours won't leak). To fix that I would have had to take the wheels and final drives off as I understand it.
Last spring I actually traded that 100 06 on a 68 06 at Landwehr's that Dale had all fixed. The 68 06 fit my current needs better (tedding and raking hay, drilling, bringing loads of square bales of hay home). The 68 06 was a good purchase. It was by far my most used tractor last year having put 125 hours on it last year. For what my farming operation is, that is an impressive amount of hours.
I took the cylinders off today. They are rusted real bad & I don't think I can get them apart. I was looking at master cylinders on the computer & found a double side by side to fit a chevvy pickup. I ordered it from NAPA. I may have to make a new bracket, But I think I can make it work. I hope it is not leaking inside. Would you have a wiring diagram of the intake manifold heater? How does that work?
I got a picture taken today. I should clean the tractors under there once and a while, it looks bad on the picture. But I think it shows what you wanted to see.
It's a little different than I thought as it is really just one unit. On the 100 06 I had bought, the previous owner rigged it up with 2 master cylinders from a '57 Chevy or something. They were shot when I got it and I replaced them with that kit from Landwehr's. Since I started maintaining dad's tractors, I have never had to do anything to the brakes on our 100 06 and 130 06 with the original master cylinder so I was less familiar.
So obviously you will not be the first to use Chevy master cylinders on a 100 06. Should work. You will have to make a bracket.
I do not have a wiring diagram for the manifold heater. How it is supposed to work is when you pull the knob to crank the engine about half way it will turn on, and you hold the knob there for a while before pulling it out all the way to crank the engine. You can usually hear a click or see the oil pressure or alternator light dim when the heater turns on. It does help the engine start if it is working.
For all of our diesel engines (Deutz, Case, Perkins, Ford) when it is real cold, we will just let the forced air kerosene heater blow on the side of the engine (side opposite the fuel pump) for a while. Even just 15 minutes with it on and they will start like its summer.
