10006 Deutz
teddy52food
I believe if I time it on the marks, it will fire too late. Pump has to turn 60 degrees to fire each 6 cylinders. Crank turns 120 degrees. So pump turns 30 degrees up the ramp & 30 degrees down the ramp. How far up the ramp does it have enough pressure to open the injector? If it is half way that is 15 degrees so the crank would be 30 degrees BTC. So I should be looking for a mark around 25 or 30 degrees before TDC on the pully, Right?
WHICH pump outlet delivers fuel when the pointer mark inside JUST passes the pointer? Trace that line to it's injector, then MAKE SURE that cylinder is on the compression stroke ready to fire. I don't see enough Deutz 8006/10006 Bosch VA pumps to recall which delivery valve outlet aligns with the cam plate mark inside. My guess is the actual timing is about 14-18 degrees BTDC, similar to the IH Neuss engines with Bosch VA pumps.
When the pump is installed with the key up it is lined up with the port for #1. The mark has about 1/8 th inch to go to line up with the pointer. If I turn it to the mark, it moves back as it is starting up the ramp. My son used sandpaper on the pulley & no marks were found BTDC. I made a soapstone mark 1 3/4 inches BTDC & installed the pump there. If I get no smoke I will move it closer to TDC by 1/2 inch at a time & see what happens. If I hit it close enough to get it to smoke, I can fine tune it from there. Thanks for the reply.
No, I don't have one. I found some info on the net that went into spill timing & degree wheel. If I can get it close enough to smoke I can get it back to where it was before I took the pump off. Engine was stuck so I took the pump off to make sure if there was something in the pump stuck, it would not break if the engine came loose. The gear that drives the pump can come out of mesh with the idler gear that drives it. That is what happened when I got the engine free & was working on it. One jug had rust & I pulled that head & jug & put new rings on it. They all check out the same on compression.
I thought you were farming with this tractor ? Heres a list of manuals although If you took the pump off without it timed youll probably have to figure it out by spill timing
Deutz Manuals
My son just reported he hit the starter & got a pop out of it. I must be getting close!. Tomorrow we will see! Thanks.
