10006 Duetz
teddy52food
What can you tell me about it? I may be able to get one. It last ran in 2012 but is stuck now. Rears are good short bar long bar, I would guess 90 % lugs. Any idea what it is worth? What make pump is on them?
If I recall the Deutz 8006 and 10006 models used the Bosch hydraulic governed VA rotary injection pump. There are no parts available if needed other than seal kits. I last repaired a leaking 8006 pump about six months ago. Converting to a Bosch inline would not be hard if the needed parts could be found.
D100-06 tractors are as tough of tractors as any that were ever built. The goods are they are very good on fuel, built with a lot of meat, fully synchronized trans, Diff lock, and creeper gear. Hydraulics are not fast, but strong. If the starter and batteries are good they start well when cold. The bad is they have very poor brakes, if any. New parts are hard to get and even harder to pay for. Used and after market parts are out there if you look in the right places. The injection pump in a VA CR. I see about one a month here, same animal I-H used on most of its German Diesel engines. Great pump, but impossible to do anything but reseal, or minor repairs to. Al
Almost bet on it. Dont horse on the throttle lever or shut off control. There is a very small dowel pin the operates the spool valve inside. I do fix this issue, but it is never fun. Al
