mschwartz
Looking for a source for tune up parts for the autolite distributer. Did not see listed on this site and no luck at NAPA. Thanks, Mike
Mike
I have new old stock Massey point and condenser kits for the 101 JR
Asking $24.00 plus shipping. Will need your address to figure shipping...If you are interested.
Also if you reply to my E-mail at bottom right, I can send you a photo.
Wayne
Are you looking for that oddball set of points? I get all my ignition at NAPA for F162 and F226, I might have one of those odd sets around.
Thanks, I am looking for part numbers for points, condensor, cap and rotor. Local NAPA thinks they can get them for me still if I can come up with numbers. Thanks, Mike
Does your 101 Senior have the Continental or Chrysler? I get Ignition from NAPA for my 44-6 with the Continental F226. I will get the #'s tomorrow and post them. Mine has the common Dist. and then there was a real oddball one also.
Here are the NAPA #'s that fit my 44-6 with the more common dist.
Points CS725A
cond. AL869
Cap AL63
Rotor AL62
12 volt coil, no resistor needed IC14SB
Hello Mike, here are the numbers that I found on my Autolite dist. GZ 4006C-1 3Z. I have a continental FC226 engine. Is the same dist. that you posted the part numbers for? Thanks, Mike
I will check the # on the dist. in the morning and post back. I will look at the dist # on my tractor, I happen to have it in the shop for some minor repairs. I was also going to install Pertronix electronic ignition on it and a hotter coil. I have that ign on some of my other Masseys and it sure wakes them up. I also have the old NAPA tractor ign. books to look at.
I found my old NAPA ignition book and under Continental it does list my dist # which is IAD6002-IBC and the ign parts that I listed in a previous post. The dist number you posted is not listed, there are about 50 numbers listed. Does your dist have a two part set of points? If so you have the odd one, and I can't help with a NAPA # for that set. I had a bunch of them but I gave them to a friend a few years back. Chris Kessel from Kessel's Massey parts posted that they had them, give them a shout, I have bought parts from them, very nice people and very good service.
the older 101 senior distributor is defferent than the 44-6 distributor. i found out the hard way when i fixed mine up. i was not able to find new parts for mine, just cleaned up my old ones as best i could and it runs real nice.
