1010 engine
dondeereb
i just purchased a john deere 1010w with a gas engine. somehow water got into the upper end of the engine, froze and cracked the exhaust manifold and has probably done other damage. engine is frozen. don"t know if i should rebuild this one or find a decent used engine. i"ve been told some combine engines will fit this tractor. is that true? any advice will be appreciated.
thanks
The 2010 gasser deck plate/sleeves and pistons are a drop in upgrade .
What serial number? There are two distinct versions of the 1010.
thanks for the replies fellas. the serial # on this unit is 19574. i believe it is a '61 model. this is the yellow industrial model with the solid non-adjustable front axle.
thanks again
don
