1010 hydro issues
jaywiz
Hello all excited to be here.
I have a early 1010 industrial with the gas engine with power steering(cylinders unhooked) and the 710 loader and a backhoe on the back. the tractor runs good and the loader/hoe both work as they should but the pump on the crank seems like it is working hard on any function and it seems under powered for the hoe, it doe leak fluid from the pump somewhere(Drips on the axle when not running) and I also have a couple of leaks at the loader cylinders and the hoe control valves.
Now for the questions, can anyone tell me what gpm and psi the crank pump should run, also if that pump is big enough to run these attachments properly? If not I am willing to replace it with a bigger pump(more gpm and psi) but how big should I go?
where is a good place to source these parts Valve rebuild seals for the hoe, loader cylinder seals, hydro pump rebuild kit, and brake parts.
Last question for now, What is a rockshaft? I am a auto tech by trade and a fabricator as a side gig. I know my way around the garage but am new to tractors. this tractor is just for homested use and so light duty but I would like it right when I need it.
Thank in advance
jay
