1010 model/ serial # plate
This is a picture of the tag on right side of my jd 1010. Doesn't say 1010. Anyone know what it means?
That is the tag of a power plant engine, your engine has been swapped. It is likely the tractor serial number tag went away with the original engine.
The 1010 used a 115 cube gas or a 145 cube diesel.
The 2010 used a 145 cube gas or a 165 cube diesel.
As stated this was from a power plant or a combine.
Blocks are the same with the exception of the bore diameter for the sleeve and deck to slide into.
