gregjo1948
Recently installed a new pto shaft with all the bearings, seals, gaskets, bushings, and etc.. for a customer. I engaged it and it spun as it should. The customer used it to rototill a garden which was not virgin ground. It had been a garden for years. After about 10' of tilling the pto stopped operating. When replacing the shaft,(first time it came in) I simply removed the cone bolts and pulled the old broken shaft out. The shaft had been snapped off externally nearly flush to the mounting cone. There was no damage to the old shaft inside the transmission. Because rototilling relatively soft ground, I can't believe the shaft broke internally. Is there an internal overrunning clutch that may need adjusting/replacing? I haven't been able to fine a diagram of the internal workings of the transmission. thanks for any help, gregjo1948
