K.D.M.
My 1010 crawler is leaking fluid from the reverser it runs good except dumps 1 gallon of fluid an hour. it comes out the side where there is a rod that runs to the outside of the frame of the crawler. in my parts manualI don't see that particular piece that the leak is coming from. how tuff is it to replase the #13952 gasket? Ithink that is the problem. thanx for any help. Kevin
Yes, you can removc the entire control-valve assembly from the side of the reverser while the reverser is still in the crawler. It's an awful job, however. I've done many. It is held to the reverser with bolts and studs. You have to get the studs out to remove.
