1010W rockshaft seal
nails1
I might as well just fess up: I have a 1010W.
I'm finally getting the hydraulics to work. So that means chasing a bunch of leaks. Right now, I'm dealing with the rockshaft seals.
I bought AM3432T seals, which looks right for the right side. But this funny rockshaft takes a larger seal on the left side. I'm asking for help identifying/sourcing it.
My rockshaft has two pistons but a single shaft/quadrant. All three drawings I have show a 2" rockshaft (both sides), but the left end of mine has a bulge (2 5/8") between the lift arm and the housing. Pretty sure I see a seal around that bulge. (I don't have either lift arm off yet. I'll probably have to heat them.)
If you happen to know this PN, I'd sure appreciate it.
If you don't know about this yet; you can go to JDParts Homepage or JD parts advisor. Either will get you to where you can find the John Deere online parts catalog there for your tractor. Enter 1010 as the model, you will get a selection of models with 1010 in them, then pick 1010 Wheel and Landscape tractors - PC 750.
The AM3433T seal D- posted is for a 2.653" shaft.
