Hello,
I am having a few issues with my 1020 John Deere. The first one is it starts with the ignition switch occasionally. Initially I thought it was the starter so I pulled it out and had it checked out and everything was good. Next I thought it was the ignition switch, but did a continuity check on it and it seems good as well. I even put it in the freezer overnight and then tried it and it still seemed to be functioning correctly. Now I am at a loss. Anyone have any thought/suggestions?? If I run a jumper wire on the starter, I now not recommended, I can get it to start.
Second issue. Once I do get it to run randomly when I am using it, it will start "choking" bad and sounds like it is about ready to shut off. I pulled the air intake hose off the front of the carburetor and gas started running out. The fuel shutoff was replaced a couple of years back. The tractor has a fuel shutoff in the feed line from the tank and it leaked and drained the tank completely. Not sure if this factors into anything or not. Anyone have any thoughts/suggestions on this??
Last item. When the tractor is in gear and the clutch is all the way out I hear a knocking noise occasionally. I tried to grease the throw out bearing but it doesn't seem to want to take any grease. Anyone run into this before?
Sorry if I should have broken this up into multiple messages.
Thanks in advance for your recommendations/suggestions
dpoc
dpoc
