cumminstinkerer
I have a 1030 that appears to have an issue with one remote on the hydraulics not wanting to hold, I am running a single acting cylinder on it, actually a pair on a hesston 1150 mower, I am using the right hand lever to run the lift function, if I go into the coupler that will raise the mower with the lever pull rearward it raises the mower but it will shortly drop, if I switch to the other coupler where I push forward to raise, it will raise and hold fine, I assume there is a seal in on the spool or a load check, I've not been into a comfort-king hydraulic valve so I am not sure, the parts break downs I have been able to find dont really show me what I am after, I would very much appreciate any help, A schematic and parts break down would be amazing as well. Thank you all in advance.
