1066 fuel pump
Cor Braakman
Hello
I've problems with a 1066. When you start the tractor by pushing the starter switch the tractor won't start it doesn't start to smoke.
I disconnected a fuel line at the pump and there's no diesel when you crank it.
When you pull start it it starts right away, the same thing happens when you'll start it with ehter. Then when the tractor runs it slow on respons of the throttle. Who has an idea what the problem is????
I'd assume it's cold---what grade diesel fuel---#1 #2---blend??? Are your filters clean--been replaced recently? If the primary filter is off, does the fuel flow freely? If it's cold, are you using Power Service[or equivalent] ? Let us know. Sounds like fuel gelling.
