1066 steering
Juneoh7
The construction company I work for has a mid- series F1066 to pull wheel packers. Moving it around the yard yesterday, I noticed it steered very hard. Could it be: (A) weak hydraulic pump. (B) plugged hydraulic filter. (C) something else I had not considered. This tractor has lots of hours and remotes /3 point are rarely used. Any info on this problem will be greatly appreciated. Thanks
Replace the hydralic filter first.If that doesnt help,you may have a weak/worn MCV(power steering)pump.they are not to hard to replace-about $350.00.
You said it has lots of remotes so if it has a few leaks maybe it is just low on oil.If you have not checked already.
