1070 Case 3 point
M tractor
My early 1070 3 point is acting up it will lift my chisel plow only enough to clear the ground . When i started his morning it would lift it all the way up like it did before. Over the winter there was some water somehow got in to the hydraulic oil and would freeze causing things to not work at all . I changed the fluid and filter 4 times and now it is clean fluid. I have steering and brakes and the remotes work but the 3 point just will not lift it up . What is wrong ?
Did you drain all the plugs 4-5? including the one above the drawbar. Hy Tran only, no cheap farm store oil. If so the hyd pump may be weak, and should be flo-metered by someone who knows what they are doing. If you would like some more help check back in.
I will get the pump pressure checked but I went out this morning and everything worked fine plowed about 4hours and no trouble kind of strange.
