107553A Cross Reference?
Kerwin
Can anyone provide a cross reference for a 107553A bearing? It's the needle bearing for the lower three-point arms with draft control on a 1650.
Can't find it in my AGCO bearing cross reference book. Thanks.
I did not replace them. I originally had plans to change them out while I had the pto out, but that turned into just having them on hand in case I ran into something. My tractor is very low hours and everything seems to be in order except for some seal weep, and I can live with that.
The manual says to remove the hydraulic unit in what I can only assume is to get at the draft control spring, but if the pto is out you can get at the spring.
