1086 hy tran leak
jpc199
my 1086 is leaking hy tran from under the clutch area I'm guessing there must be a seal between the clutch and transmission gone bad. is that something that can be replaced by splitting the tractor at the clutch is there any other possibility for the leak it only leaks when it is running thanks
Your leak is more then likely from either the IDPTO shaft and it also be the input shaft leak . Yes you split at the bell housing and move the engine ahead and give yourself enough room to fit you body between the two then ya remove the throw out bearing and shaft and you then remover 4 3/8th bolts and the IDPTo input shaft comes out and you will find a seal inside and one on the out side . Now it is wise to inspect the Pressure plate at this time for ware on te IDPTO splins as you may need to replace the PPa and the input shaft . It is wise to replace the bearing at this time and add in and oil slinger also .
thanks I will probably split this tractor in about a month when I have the chance and I might be back to ask u some more questions when I get into it . itdid seem to leak worse when the pto was being used I have just been adding more hytran and still using it but its starting to get expensive thanks
