1086 Hy-Tran
Down is fine, but it does not matter. A good recommendation is to put 5 extra gallons in it anyway. There is an Oring and connection on the intake to the MCV hydraulic pump that can leak air and the extra oil covers it. The extra oil is harmless. Jim
The lift cylinder only 'holds' a quart or so.Position doesn't matter.I rutinely run 5 gallon 'overfull'.Everything seems to work better.
