scott vaughan
How much does a 1086 IH weight. I got one given to me and need to go get it 55mil away.
(quoted from post at 07:06:08 07/21/10) I just hauled mine 40 miles with my neighbors 20' gooseneck trailer rated for 14k with my powerstoke, and had no problems. I was not in a hurry, and ran 50 mph most of the time.
If it is in good condition, I would not be afraid to drive it that far. Mine is not!
Good Luck
(quoted from post at 17:51:16 07/21/10) Very interesting as I met a State Trooper, and the County Sheriff
passed me and waved![]()
(quoted from post at 11:44:56 07/22/10) Rusty I am curious as to why you think a tractor with 12000 lb. official shipping weight (bare tractor) will load 14000 lb. GVWR trailer that probaly weigh 3000/4000 empty to twice its capacity. I have seen lots of similar rigs cross scales and be given green light without hesitation.
On interstate system weights are set by Federal regulations and 23 CFR 658.17 (f) says.....Except as provided herein, States may not enforce on the Interstate System weight limits of less 20,000 lbs. on single axle, 34000 lbs. om a tandem axle, or the weights derived from the bridge formula, up to a maximum of 80,000 lbs., including all enforcement tolerances. States may not limit tire loads to less than 500 lbs. per inch of tire tread width, except that that such limits may not be applied to tires on the steering axle. States may not limit steering axle weight to less than 20,000 lbs. or the axle rating established by the manufacturer, whichever is less. For complete Federal Weight limits do Google search for "23 CFR 658.17".
