1086 Instrument warning lights
I have an old 1086 with faded gauges. The warning light on the far right of the instrument cluster(4 red warning lights above the gauges) is lighting up, but I don't know what it means. I know the far left light is the transmission oil psi, but unsure what the remaining 3 are. Any help?
Different tractor, I've got a row of indicator lights; left to right they're a lightning bolt, a round thing with a drop in the middle and two arrows pushing against it, two curvey arrows, then another set of two curvey arrows, then a big 'D' with bars going off to the left.
Lucky, I still the owner's manual.
But this is the stupidest thing, every device, every tractor, every manufacturer invents it's own new set of symbols, which we have to learn.
I say, we already got a list of symbols, it's called the English language.
How about calling things; 'Oil Pressure', "Water Temperature", "Alternator', "Turn Signal'......
From left to right low trans pressure, service brake light, air filter restriction, low coolant. That's how my late model 1086 is.
Thanks for the info, that helps a lot. I had to drain the coolant a few days ago and when I started the tractor back up that light was on. Makes perfect sense that it hadn't had time to cycle through to make the switch go off.
