11.5L15 implement tires
tjdub
Does anyone know the rim width required for 11.5L15 tires?
9.5L15 requires 6" width
11L15 requires 8" width
12.5L15 requires 10" width
11.5L15 is apparently a very odd size, and I haven't been able to find this with google. The only thing that comes up is my post from when I asked this same question in the implement forum here.
Requirements are optional. No such thing as a 9" rim, I don't believe. 11.5-15 on an 8" rim would give you 1 3/4" on each side of bulge. 11.5-15 on a 10" rim would give you 3/4 of an inch of bulge.
Therefore, I would Run it on an 8 inch rim - less chance for the bead to pop off the rim while turning if you happen to have low air in a tire.
Sure you could run it on a 10" rim, but I wouldn't like it. For one thing, if I was ever low on air and on a hillside, that bead would pop right off.
