caterpillar guy
I find it doesn't matter who's plugs by brand I buy none of them stand up anymore. I have plug trouble with all of them unless I go to 50 amp plugs for everything. I even had to finally change out one of those after 15or 20 years use. They all just seem to burn out the guts to them .Even if I put a rated or over rated plug on things. There is no spring to the pieces in these new plugs so if they get used in a slightly off direct plug in the prongs in the plugs can't make a good connection. Like somebody pushes them in at even the slightest bit of an angle or the female will not make the connection. When they used to make the double piece prongs on the males ends I used to get a thin screw driver or knife blade inbetween them and open them up just a wee bit so they would then make contact and work. Now all these cheesy single piece junk can't do that with them and the females are so cheesy and junky they just can't handle the amperage they are rated for. I rarely ever use less than 12 ga wire for anything but a Christmas tree light bulb not even if there is 2 of them in the string it will have 12 ga. wire. I would not even use it to wire a plug for your charger for your razor or other innocuous item with less than 3 amps draw. I do believe I use big enough wire to carry the load with plenty of capacity for the use on things. So in the long run your telling me to just accept this junk with no heavier plugs available and I've been to our local electrical shop where most of the Wire burners go to get parts and wire. The only guy in there that used to know what I wanted to do and was good at helping with suggestions died so not there any longer the rest are pretty much just useful idiots.
