BigJohn23
Have 1100 tractor that was on an auger and the pto got overloaded. Still have hydraulics, brakes, and steering. I CANNOT turn the pto by hand with tractor running or shut off so im assuming the clutchpack is welded together.. How do I check and how do I fix if that is the case?
You will need a service manual. Rear PTO gearset housing comes off, shaft to the gearbox comes out, then the charge pump cover assembly needs removed under the floor in front of the seat. Then another short shaft comes out to allow PTO clutch pack to lift out the top.
