1105 3pt weak
mhudgins
My 1105 has a weak 3pt lift
Steering is working fine starts working as soon as you crank it don't have to rev the engine to get it steering
Remote hydraulics work great
This winter I put in a rebuilt radial pump because mine started to leak at the seal and then went ahead and replaced the pump
But any how the lift goes up and it'll pick up a couple hundred pounds but that's it
When the lift is in transport position the steering get stiff still turns just have to really crank on it
This is the first time I've used the lift mostly pull my chopper and mower with this tractor
But I bought a big tiller to use this year and now I can't get the lift to pick it up
Is this signs the pump under the floor board needs attention or something else
I'd be looking at the charge pump under the platform. Pressure test the system first, but the 11xx series tractors were known for hydraulic issues.
I'd try 2 things first.
change your filter, and clean the intake screen. Sounds like you are starving the system and the 3 point takes a lot of oil when working.
Then check your lift pump output. You aren't going to be happy when replacing that little pump. last new one I got was about 1800
I just read where you say the steering gets bad when the lift is all the way up..
regardless of load??
When it's 'up'.. do you hear a lot of hydraulic whining inside the lift cover? If so, you got lift valve issues. might be just a blob of crap in the pressure relief valve keeping the poppet off the seat. Worse case would be a cracked valve body.
Make dang sure you got enough oil in there too!
