1105 draft controls
Anyone have apdf of the1105/1135 op manual that explains some of the menagerie of the draft sensing adjustments, I have the lever in the cab figured I think, and the turn knob I believe, My next considerations are the location of the top link mounting bar on the tractor, has 2 sets of holes, the upper and the lower, and I also notice a pin and atleast 3 locations in the linkage, what do all of these affect, and where do we locate each one for different combos?
Hi, We had an 1100 , I believe the top link arrangement was similar to your tractor. The position of the top link and that pin and 3 hole affair all affect the sensitivity of the draft control. To be honest you its a case of experimenting with different positions depending on the implement you are using. We bought a big cultivator for her and the first time we tried it out it seemed as if the whole tractor was going to shake itself to bits! The top link literally shivered and shaked. (We had never had any problems before using a fully mounted 5 furrow plough) We found that if we moved the pin into a different hole it cured the problem.
