1175 Case 3 point lift problems
kz9d
Just bought a Case 1175. I put a blade on the 3 point left and it will not lift execept when it is ai full throttle and only about 2in. When I throttle down the lift lowers.
Have you checked the pressure at the remotes? That is your next step. If pressure at the remotes is good, you likely have a problem in the valve. If there is low pressure at the remotes, odds are the pump is kaput. Good luck.
I have not put a gage on the remotes yet. When I move the remotes the trator loads up and I can tell they have pressure.
