12 inch drainage pipe
showcrop
Where is a good place to buy a 20 foot 12 inch poly drainage pipe and what should I expect to pay?
If it is a driven on culvert and ~3 to 4 feet under the gravel or less, it will take more than a pipe. Farm Fleet has them for just under $200.00. Not a typo. They are double wall corrugated ABS pipe. Jim
As Janicholson said. If this is a culvert in a driveway you are
looking at $200 for smooth inside corrugated outside plastic
pipe. Comes with a rating of about 20,000 lbs per axle. You
can get it plenty of places like Home Depot and such.
In my area the county drainage department will deliver a piece
for you. That way you know it will pass code requirements.
There are no code concerns. it is for a "beaver deceiver". Does it float? one end needs to submerge on the upstream side of the dam.
Any municipal water projects going in near you?
Public city water lines use a lot of large diameter pvc pipes.
Usually seafoam green or blue.
menards has it about 133 dollars. here is a link. i used this for the same thing. cable a couple cinder blocks together to weight it down.
poke here
(quoted from post at 19:26:19 10/30/22) menards has it about 133 dollars. here is a link. i used this for the same thing. cable a couple cinder blocks together to weight it down.
poke here
Thanks Glennster. I can see that it is single wall which I haven't come across yet around here, but it is what I should get because of course it will bend better. Unfortunately the nearest Menards is 700 miles away.
