12 inch tires // no flat compound?
I am creating a storage dolly using reclaimed low pressure 12 inch tires that have tubes. Wanting to set the tires up so that >>as they sit with a load of plastic totes from year to year in storage the tires DON'T go flat.
???? Is there a compound that one could put in the >>tube tires<< to keep them from going flat? [ ride or softness there of is not a factor since the cart is going to be parked.]
Wm.
they make foam filled "flat proof" tires like that. TSC has em sitting on the shelf. However,if you want a wheel that wont get a flat spot,you're gonna need a steel wheel. Even the foam filled one will get a flat spot from just sitting with a load.
While creating the cart, create "axle lifters" that will lift cart axles and tires up so that the static weight is not on the tires during long term storage.I
Could be mounted or just a long pry bar so you can place blocks under axle.
I would suggest urethane casters, even they will get flat spots sitting.
Or flat free wheel barrow wheels, Harbor Freight, Northern Tool.
Having them foamed will be cost prohibitive.
