Dawgbone
- Location
- West Texas
Where can I pick up one for my 8N? Would like one with low amp and one that doesn't cost too much.
(quoted from post at 19:33:03 12/10/22) Yeah, I had a one wire on mine that had to be revved up to almost full throttle before it started charging. It finally quit working so I'm
going to town next week to get a 3 wire one.
Your 1 wire most likely has all 3 terminals, have you tried energizing it with a jumper wire at idle? You can wire just like a 3 wire and it should work instead of buying another alt. or buy a reg and put it in yours.(quoted from post at 18:33:03 12/10/22) Yeah, I had a one wire on mine that had to be revved up to almost full throttle before it started charging. It finally quit working so I'm
(quoted from post at 21:50:36 12/11/22) I use a 1980's-1990's GM CS-130 alternator. Theyre 20-30 bucks at a junk yard. Make your own brackets, use a hardware store turnbuckle for belt tensioning, and
a fuse type GM diode inline from the ignition switch to the alternator's exciter circuit to keep it from back-feeding your coil and youre charging 10+ amps at
idle for under 50 bucks in no time!
ome posters don't read, just talk. To others, an alternator is an alternator, no matter 10DN, 10SI, CS130, etc. :roll:(quoted from post at 13:11:12 12/12/22)
NOTE for a CS-130
