12 volt battery
Michael Soldan
What reading should I get from a battery sitting on the bench ? I believe it is fully charged. I'm thinking I shouls get a reading of around
12.5 Volts.
12.5 is a tad bit low but for the common house hold VOM that could well be the voltmeter being off. 12.6-12.7 is a full charged battery but again that is with a calibrated meter which your not likely to own
Michael actually the voltage of a fully charged lead acid battery AT REST AND STABILIZED depends on the temperature. Here are the voltages and specific gravity at different temperatures:
Temperature: 57 degrees Fahrenheit
Percent Hydrometer Unloaded
charge reading voltage
100 1.258 12.59
75 1.203 12.26
50 1.153 11.96
25 1.113 11.72
0 1.093 11.60
Temperature: 67 degrees Fahrenheit
100 1.262 12.61
75 1.207 12.28
50 1.157 11.98
25 1.117 11.74
0 1.097 11.62
Temperature: 77 degrees Fahrenheit
100 1.265 12.63
75 1.210 12.30
50 1.160 12.00
25 1.120 11.76
0 1.100 11.64
Temperature: 87 degrees Fahrenheit
100 1.268 12.65
75 1.213 12.32
50 1.163 12.02
25 1.123 11.78
0 1.103 11.66
John T
Sorry, I copied and pasted the chart but it doesn't come out right when I press submit grrrrrrrrrrrrr so I will try this:
Full charged voltages at X temperature are as follows"
57 Degrees 12.59 Volts,,,,,67 Degrees 12.61 Volts,,,,,,,,77 Degreees 12.63,,,,,,,,,,87 Degrees 12.65
Thats all I have time for lol
John T
100 1.258 12.59
75 1.203 12.26
50 1.153 11.96
25 1.113 11.72
0 1.093 11.60
100 1.262 12.61
75 1.207 12.28
50 1.157 11.98
25 1.117 11.74
0 1.097 11.62
100 1.265 12.63
75 1.210 12.30
50 1.160 12.00
25 1.120 11.76
0 1.100 11.64
100 1.268 12.65
75 1.213 12.32
50 1.163 12.02
25 1.123 11.78
0 1.103 11.66
Every 3 months my Fluke VOMs, scopes, megger,amp clamps and ground tester are calibrated, as well as my torque wrenches,mics calipers,dial bore gauge and dial indicators.
u are good. the average person wont pay attention to .1 or .2 of a volt difference. and if its reading that it will crank your tractor. ideal is to load test before using a battery. volts can fool you.
