12 volt coil for 8N--resistor?
GPO
Early 8N (front distrib.) with 12 volt system: the coil is shot--got overheated. If I get a new 12 volt coil (over the distributor type) is a resistor necessary? If so, what bad happens if I don't use a resistor?
Go to www.sssnssstractorssclub.com and to the how to section. There is an article there om converting the N tractor to 12 volt. NOTE: remove the "S's" in the address above to get there.
even the 2.5 ohm 12v square coils still need the oem ballast resistor.
if you choose not to use it.. plan on replacing coils and points sooner than needed.
soundguy
