don't see any measurements, can't "know" if cam was worn out or not! Wouldn't ever say impossible, but never see even one worn out & believe very highly unlikely that I ever will.(quoted from post at 07:53:03 04/06/15) " I cleaned the points but found the cam was too warn to get to the correct gap. So I installed a petronix ign, by passing the oem resistor and installing the correct ballast resistor for the petronix unit. Still no fire"
So you are counting on the EI to fix the worn cam?
I'm not sure about your specific unit, but some makers include a plastic magnetic cam sleeve-to-ignitor module gauge in the installation kit and further state that it should be adjusted to 0.030 inch. Variations will alter dwell & if too far off will not switch.
75 Tips
lobal warming did it!(quoted from post at 08:10:27 04/06/15) How does a river cut a canyon. Time and friction. Get one spec of debris on the block, and its now a lathe. Dirty tools, dust, missing dizzy gaskets, 70 years, and abrasive particles. Soot is an abrasive. might even be some ozone in there![]()
