12 volt conversion Farmall H
Joshua Slo
Hi I converted my 1946 Farmall H over to 12 volt this week. Can I use the old original 4 setting light switch? It sure is a complicated looking thing. I will pick up some 12 volt bulbs but not sure how to wire the switch or if I should buy something new. Any thoughts? Thanks
Remove the field wire that went to the generator or fold back on loom and tape at generator end, put in your 12 volt bulbs or lights, it will work fine just have 2 off
positions, then dim and bright rotating switch clockwise.
(quoted from post at 05:04:40 04/16/20) Remove the field wire that went to the generator or fold back on loom and tape at generator end, put in your 12 volt bulbs or lights, it will work fine just have 2 off
Thank you.
