12 volt conversion kit sold for 2n
Shawn O
Just got a 12 volt conversion kit and it has 3 terminals on alt which being b plus ,w,and d plus I know b goes back to battery but not sure of other two. With only b hooked up pulled pos cable off to see if alternator was charging and tractor began sputtering and backfiring any idea were other 2 connections go.
(quoted from post at 00:27:05 03/22/15) Just got a 12 volt conversion kit and it has 3 terminals on alt which being b plus ,w,and d plus I know b goes back to battery but not sure of other two. With only b hooked up pulled pos cable off to see if alternator was charging and tractor began sputtering and backfiring any idea were other 2 connections go.
hat kind of alternator is it? "w" & "d" do not look like the typical Delco 10SI. Where did you buy it?
The alternator came with a tractor I bought it came with a kit
with 12v coil and everything it is definitely not a delco
(quoted from post at 12:44:25 03/22/15) The alternator came with a tractor I bought it came with a kit
f you can read a name off the casing & or post a picture of side & rear, some one of us might be able to ID it.
