obradovich08
what is a good alternator to use for a 12volt conversion on an LA?
rent, I think there may be some "mixing" as to the #1 & #2 functions, etc. Since you appear to have accomplished same, then maybe finger/keyboard problem. he he he(quoted from post at 10:05:47 01/18/14)
what I have used on a 12 volt conversoin has always been easy to do. I start off with the Delco/Remy 10-SI because it has a built in Voltage regulator and it only needs three wire hook ups. 1. Battery, 2.#1 termianl conducts battery current to the rotor windings for the excitation circuit and to the amp meter.2.terminal receives battery voltage so that the voltage regulator can reat to the system operating conditions. Remember that the #2 that feed the Alt. with voltage must have a shut off so it does not drain the battery when it is not runing. If you have a Dist. and coil you might have to run a ballist resister that is if you are burning the wire up from you ignition to the coil. I hope this might have help you out. good luck Brent.
