12 volt conversion
it is a front mount distributer from a 1949 8n. I am replacing the 6 volt coil with a 12 volt and getting rid of the resister block
if your 12v coil has an internal resistor, you are fine. if the 12v coil does not have an internal resistor, you will need the external ceramic one.
Well so far there has never been a true 12 volt coil made for the front mount N series tractors and they are ALL 6 volt coils for the most part so a ballast resister IS in fact needed unless you like to spend a lot of money replacing coils. What is made now day and called a 12 volt coil at best is maybe an 8 volt coil which will not stand up to 12 volts for long. Check the archives in the N forum and it has been talked about over and over and over again
Hobby farm
As old says, for that application, LEAVE THE FACTORY BALLAST RESISTOR IN PLACE for use with the "so-called 12-Volt" front-mount coil.
The "so called 12-Volt" square-can front mount coil STILL needs that resistor.
The points and condensor from the 6-Volt system will be fine on 12-Volts.
when you say ballast resister, is that the 3 terminal resister under the dash or are you talking about the white one?
The way I fixed a N series with a front mount distributor was to build a plastic plate to go where the coil mounted. In this plate I mounted a spark plug centered over the high tension contact. I removed the ground electrode from the plug and rigged a spring loaded contact. For the point connection, I used some brass all thread also with a spring loaded contact. This way any standard automotive coil could be used with the front mount distributor. This modification would work on the flathead V-8 also.
Kent
