12 volt LED lights for Allis C
David(CO)
I am converting my Allis C from 6 volts to 12 volts. I understand that I need to install 12 volt light bulbs. I would like to use LED lights that would screw into the bulb fixture. Is such a thing even made. And if so where can I buy them?
If you still have the original 6 volt head lights they used a # 1133 bulb. The original bee hive tail light used a # 51 bulb. Both are single contact bayonet type bulbs, not screw in. If you search for the Wagner Miniature Bulb catalog and look up those numbers you can find all the dimensions. Since you are converting to 12 volt be sure to change to negative ground as well since most LEDs are polarity sensitive and I think all the single contact bayonet type LEDs will be for negative ground.
