12 Volt to 6 Volt
John B.
I just got done wiring up an old Continental engine in my portable air compressor. I wanted to keep it 6 volt so I bought the 6 volt coil and I did by a 6 volt electric fuel pump. It was cheaper than the mechanical one. Well I checked out my generator and it won't charge. So I decided to look on ebay for a 6 volt alternator. But I found an electronic 6 volt voltage regulator to put in a Delco alternator that I have in the shop. So I ordered it and it only cost me $18.00 dollars. That's a lot cheaper than buying a new or rebuilt generator or alternator.
The engine starts and runs just fine on 6 volts. It will be a 6 volt negative ground system rather than a positive ground system like it used to be but that doesn't matter. I'll have to change the wires on the coil and amp meter to match the negative ground now.
I regulated at 12 volt generator to 6 volts once after a VW engine change. Made it a super generator, charged at slow idle when needed. My new solid state regulator gave me very long battery life too. The alternator regulated down to 6 volts will work super also.
Gerald J.
