1210 David Brown injector oil
mdhill
Thought I would post a pic of the oil ports for the 1210 injector pump. Drain hole is located directly under the level hole.After I put new oil in the injector pump is there anything else I should do before trying to crank the tractor? As I said in my previous post there was alot of water in the fuel system. It has new priming pump, new fuel filters, a boiled out and lined fuel tank...anything else I should check??????
I'd just try it after bleeding the air out of it. I suspect you are fine. I'd add a bottle of fuel treatment to the first 5 gallons of fuel to deal with any residual water.
The last 1394 I fixed had filters nearly full of water(actually ice cause it was cold when I fixed it). sight glass 3/4 full of water(glass broken when it got cold), and 1" of water in the tanks. For the life of me, I can't figure out how it ran last fall before the cold set in, but it did.
I was looking at my 995 and I didn't see a oil port for its injector pump. Do you have to do the same thing to a 995 injector pump????
