1210 engine oil pump removal
herk
Hello a freind asked me how to remove the engine oil pump he has removed the oil line and bolts that he can see , is their a hiden bolt ?? I have not seen this so I don't know anything about how it is mounted . Thanks Bryan
No "bolts" required to be removed.
There is a tapered screw hiding behind a cap nut on the side of the engine block that holds it in. If memory serves, it takes a 3/4" wrench, then a big slotted screwdriver. The oil line takes a modified 13/16" wrench. bend the line out of the way, then the pump will pull down and out.
