125 cub cadet hydro unit
Have you checked your fluid level? Is you cam stop down by your right foot stopping the rams movement? When was the last time you changed your hytran and filter? hope this helps. Kent
Does the tractor MOVE (indicating that the hydro's charge pump, which also supplies the oil for the hydraulic lift) is functioning?
peanutbaby:
What is odd to me.......is that the 125 did NOT come from the Factory with a Hydraulic Implement Lift. There was a Aux Hydraulic Unit that could be added as an option but was independent of the Tractor System.
Don't know what you got.
This may be an add on system because it is separate from any thing else. i have two of these pump set-up. It took both to get one to work. Thanks
I was unable to pull up that page you supplied. It came up error. I will try to send it with this message.I have reversed the hoses and it will extend the ram but will not retract it. I have a photo of the hydro unit. You can e-mail me at the above address.
peanutbaby:
Sorry for the bad link. There seems to be a glitch on this forum of late.
Copy and paste this into your Browser URL go to window: http://ccmanuals.info/pdf/NF Hydraulics Install.pdf
That should take you to the Installation Manual for your unit.
