1270 3point stays up while running
Joewisco
I just baught a 1270 case that every thing works on it.. but the 3 point .. when sitting it goes down but as soon as you start it it goes up and stays there and kind of pulsates up and down slightly just would like to know the possibilities on what to fix .. thanks
You have a internal leak, that is why it settles when not running and going up and down when running. The most common leak I see in that system is the seals on the 3 pt pistons. Another place of leakage can be the 3 pt valve itself. Other than a external hyd. line leaking those are the only two place for a system leak like you have, Rod.
