I have a 46 front mount distributor and I am swapping over to a 12v conversion. I bought the kit here at YT. I am very confused, the instructions say to use the original ballast mounted on the dashboard. My tractor did not have this installed when I bought it, it had the rectangular shaped two terminal resistor instead.
My kit came with a new resistor, but says it should be installed inline between the existing resistor and the coil. It shows the original resistor as being a three post/terminal. Instructions say to use the new resistor if needed, but does not offer a way to see if it is needed or not.
I will post a picture of the resistor where it was originally mounted.
[/img]
[/img]
