Definitely read your installation instructions (for 1247, their sheet says 3 ohms minimum) and some of the FlameThrower coils are as low as 0.5 ohms. I fully expect the 1247 module & a 0.5 coil will let the smoke out.(quoted from post at 10:10:01 02/24/09) I forget weather or not a resister is needed on a side mount 8N, with 12v electric igniton and flame thrower coil. The tractor had a resister on it that converted 12v to 6v, i know that one is not needed, however is another needed?
thanks,
Zach
No, Don, I have not measured the 0.5 ohms, it is just that they list several FlameThrower coils of 0.6, 1.5, and 3.0, ohms and I was suggesting that since he didn't know what he had and that several were available that he best find out before damaging something expensive. If he got it all thru you, then I'm sure he has the right combination of matching components.(quoted from post at 13:26:38 02/24/09) Jesse....the "flame thrower" from Pertronix says right on the coil that it is a 3.0 ohm coil.It also says "made in China".The ones that I have measured,measure about 3.3 ohms.If you are measuring .5 ohms,there is something wrong.
If I was using a flame thrower,I would widen the points gap to about .035,since this is why one would use the 40000 volt coil,to be able to open the points and gain better fuel efficiency and more power.IMHO don b
(quoted from post at 08:00:33 02/24/09) Zack.......did you read the instructions that came with yer 12v "FlameThrower" electronic ignition coil??? That is why you pay BIG $$$. Call the electronic ignition coil manufacturer and ask. Simple, eh???
As a general rule, real 12v coils don't need extra resistance. That is why they are 12v coils. Sheesh!!! ........Dell, yer self-appointed sparkie-meister
I can't tell if you got your question answered or not, but just because it says 12v on the coil does not always mean it can be used without a resistor. Some need the & some don't. It is best to do as the Electronic Ign Module maker says, BECAUSE, only he knows how much current his module will tolerate & still live. As the Pertronix data sheet here shows, they want 3 ohms or more & if the coil is less, then add the difference to get up to 3 ohms. That being said, Pertronix makes many different modules & coils, so you need to check with them. From Don-b's response, it sounds like he sells only the 3-3.3 ohm coils (safe w/o res).(quoted from post at 16:43:49 02/24/09)(quoted from post at 08:00:33 02/24/09) Zack.......did you read the instructions that came with yer 12v "FlameThrower" electronic ignition coil??? That is why you pay BIG $$$. Call the electronic ignition coil manufacturer and ask. Simple, eh???
If there was instructions then i wouldn't be wasting everyone's time on here. I was under the impresson that 12v dosent need resistor, however there are diagrams out there that show them...
Big money? Hell, you buy the electric ignition once and yer done, there worth there weight in gold vs points IMO
Zach
